2005 650 4x4i brute force
Old Dec 23, 2008 | 12:07 AM
eggenz7's Avatar
Default 2005 650 4x4i brute force
i just rebuilt the topend and adjusted the valves. the thing busts off every time without fail and idles just fine. but just off idle to about middle throttle it spits and sputters. if i hit the throttle and let off then hit it again it will push over that spot and run good at 1/2 to WOT. any ideas?
Old Dec 24, 2008 | 02:30 PM
haoleboy's Avatar
What octane gas are you running?
Old Dec 24, 2008 | 03:57 PM
eggenz7's Avatar
93 i think. thats what i had on hand. if i put in in gear and punch on it it doesnt act abnormal so im not really concerned with it
Old Dec 25, 2008 | 03:37 AM
Hayashi's Avatar
It seems the carbs are running little too lean at the mid range where it sputters a bit. Shim the existing jet needles or install next size up (richer).
Old Dec 27, 2008 | 07:47 PM
WhatWasIThinkin's Avatar
I agree with shimming the needles. Also turn the feul screws out 1/4 to half turn.
Old Dec 28, 2008 | 12:12 AM
eggenz7's Avatar
apparently i had to take too much material off the jug to get the scratches out of the front cylinder. it has piston knock and i think it may have broke a skirt off. get to tear into it again it seems
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 10, 2015 06:45 AM
ylomnstr
Sep 4, 2015 05:02 PM
