Track Kits
Old Dec 23, 2008 | 02:21 PM
sportsman70004's Avatar
Default Track Kits
Has anyone out there ever put track kits on a 2004 Sportsman 700? I can buy a set pretty cheap but after talking to my dealer, he states that they will not fit on the 04 models only 05 and up? Any reason why? The only difference between the 04 and 05 that I know is the plastic changed?
Old Dec 23, 2008 | 02:40 PM
Mongrol's Avatar
"Official Site Skeptic"
Default Track Kits
let me check and I'll get back asap.
Old Dec 23, 2008 | 02:49 PM
Mongrol's Avatar
Default Track Kits
The 2002-2004 1/2 use a different track than the other yrs of 700. If memorie is correct it has something to do with the front hubs, a different size I think.
Old Dec 23, 2008 | 02:57 PM
Default Track Kits
I thought these bolted on to the hubs and then have some type of attchment kit to hook to the A frame...
Old Dec 23, 2008 | 03:09 PM
Mongrol's Avatar
Default Track Kits
Thats right but has some thing to do with small hub or larger hub. The dealer should be able to tell you the difference on the machines. or contact Gary at;
www.atvtracks.net
verey knowledgeable and a good guy.
Old Dec 23, 2008 | 03:17 PM
Default Track Kits
Thanks for your help Mongrol...i have a friend that works for Polaris in the part department...maybe he can answer my questions. If it is simply the hubs...well then i will change the hubs as i really want to put a set of these tracks on.
Old Dec 23, 2008 | 03:33 PM
Mongrol's Avatar
Default Track Kits
Good luck, you'll have a lot of fun with the tracks.
Old Dec 23, 2008 | 09:18 PM
Default Track Kits
Found out the hubs are the same on the 04 and 05...any other reasons out there that you can not put track kits on the 04 Sportsmans (Prospector Track Kits) specifically?
Old Dec 23, 2008 | 09:25 PM
Mongrol's Avatar
Default Track Kits
The only other variable is the mounting hardware. I put tatou tracks from a 600 polaris on my 08 400HO. Had to modify the mounting brackets a bit but its worked good for 2 yrs. You might post your question (before you make the purchase) on www.trackshare.com. Someone there will have the answer. Good luck.
Oct 10, 2015 10:20 AM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 16, 2015 12:13 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
