Trail Blazer Potential?
Old Dec 23, 2008 | 09:53 PM
Mjones4321's Avatar
Default Trail Blazer Potential?
What exactly can be done to this quad. I would like to know its potential. Aaeen website or what ever claims like 40 hp with a stage 3 kit. Not sure how a pipe, a carb and porting the head will make it go from 22 hp to 40. But who knows lol Also as far as jumping it? Can it be built to take abuse? If so what kind of mods can i do to build it up. I figure on since I already got it i might as well turn it into a little project bike.
Old Dec 23, 2008 | 10:25 PM
ftwflh's Avatar
you have to ralize you have a GENII Trailblazer and hop ups are not that plentiful.Ritter would be your best bet on a pipe and clutch kit.But before dumping $$$$ into mods you need to get EVERYTHING else up to new standards.Like brakes,tie rod ende,ball joints,swingarm bushings,rear axle bearings,steering opst bushing..I am sure these are all wore or shot on a 96 model.
If you just want some more snap out of it put in a Polaris white or green primary spring
Old Dec 23, 2008 | 11:20 PM
Mjones4321's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ftwflh
If you just want some more snap out of it put in a Polaris white or green primary spring</end quote></div>
O deffenintly Changing out all the steering and suspension bushings. The things a total project. Actually in the process of ordering a few of those things now lol.
Old Dec 23, 2008 | 11:31 PM
4strokemurder's Avatar
go with a reed conversion, they say they can give 400exs a run with a reed conversion.
azbadboyz.com
its like 525$
Old Dec 24, 2008 | 12:11 AM
drlang's Avatar
You don't need a reed conversion to play with a 400ex. Port, pipe, and clutching and away you go. Doc
Old Dec 24, 2008 | 12:35 AM
huh? thats it to mess with a 400ex?
Old Dec 24, 2008 | 07:59 AM
ftwflh's Avatar
dont let the 250 fool you.It is a potent little motor with just what Doc said
Old Dec 24, 2008 | 09:53 AM
brianvabeach's Avatar
Put it this way. The Predator 500 stock has 42hp, With the aaen stage iv kit, the Trailblazer 250 gets 42HP.
Old Dec 25, 2008 | 12:41 AM
how much would port, pipe and clutching cost me roughly?
Old Dec 25, 2008 | 12:46 AM
ftwflh's Avatar
You are looking at roughly $500for a pipe,silencer,clutch kit.(best bet is Ritters Stage1kit)it is in the $300 and porting will run you close to $200 or a little more.+ rings and gasket kit.I wouldnt mess with porting until it is time for a top end.
