1996 Scrambler
Old Dec 24, 2008 | 11:53 PM
nasserz's Avatar
Default 1996 Scrambler
My scrambler died last night after just installing a new plow.
I tore the engine apart and found the cable for the oil injection pump stuck wide open which explaines the smoke. However, the cyl and piston have 2 grooves and I can't figure out why. Prior to the taredown, I did a compression test and afte 3 revolutions it had about 30 psi and would leak down immeaditly. But after 5 rev it had 100 and held. What gives? Also it has been bored once 30 over,can it be bored again? How do I remove the pistion from the pin without removing the crank? Please let me know. Nasser
Old Dec 25, 2008 | 12:19 AM
ftwflh's Avatar
You can bore these up to .080 over.The cables stick when they are not properly oil and cleaned at least once a yr.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
chewy78
Sep 8, 2015 10:37 AM
