blaster jetting
it could be a 240 but be careful some people think that when you bore it .40 over its now 240cc. not true to make it a 240 either you bore out the whole sleeve and press in a new one or you bolt on a new big bore kit like mine or ct racings.if its knocking its usually lower end but that noise can be confused with a loose cylinder, head or blown gaskets. i would start there first. good luck
i have stock gears and 1st gear is . if im racing or want to launch quick i just start in 2nd. i thought about changing the ratio but this really works for me . i mostly do trail riding so i like the short gears for climbing. i have so much power that it makes up for the short gears
any year but some small fabricating is nessesary. i made a bracket in the rear for the caliper but recently bought an aftermarket aluminum carrier . its made to accept a hydro caliper. for the front i welded on a small plate and extented the cylinder arm with a pc of stainless steel rod. i will post some pics. im also going to post pics of the templates for the brackets. thinking about making some extra brackets to sell .
