blaster jetting
Old Dec 25, 2008 | 06:13 PM
stephen19851209's Avatar
Default blaster jetting
which jets are better vitos or moose?
Old Dec 26, 2008 | 02:18 PM
qsportgoat's Avatar
im pretty sure there the same. they are made out of brass, so the quality should be the same.
Old Dec 26, 2008 | 04:25 PM
ok and another thing the guy i got mine from said it was bored to 240 and its got a knock to it but it runs fine is that normal cuz i see ur is bored to thats why i ask?
Old Dec 26, 2008 | 09:49 PM
qsportgoat's Avatar
it could be a 240 but be careful some people think that when you bore it .40 over its now 240cc. not true to make it a 240 either you bore out the whole sleeve and press in a new one or you bolt on a new big bore kit like mine or ct racings.if its knocking its usually lower end but that noise can be confused with a loose cylinder, head or blown gaskets. i would start there first. good luck
Old Dec 26, 2008 | 11:53 PM
are your 1st and second gear real short?
Old Dec 27, 2008 | 12:13 PM
qsportgoat's Avatar
i have stock gears and 1st gear is . if im racing or want to launch quick i just start in 2nd. i thought about changing the ratio but this really works for me . i mostly do trail riding so i like the short gears for climbing. i have so much power that it makes up for the short gears
Old Dec 27, 2008 | 10:51 PM
what year warrior hydro rear brakes bolts up?
Old Dec 28, 2008 | 09:20 PM
qsportgoat's Avatar
any year but some small fabricating is nessesary. i made a bracket in the rear for the caliper but recently bought an aftermarket aluminum carrier . its made to accept a hydro caliper. for the front i welded on a small plate and extented the cylinder arm with a pc of stainless steel rod. i will post some pics. im also going to post pics of the templates for the brackets. thinking about making some extra brackets to sell .
Old Dec 28, 2008 | 10:07 PM
let me know if you do that i might wanna buy some. i wish i had a welder i know how but i dont have one
Old Dec 28, 2008 | 10:21 PM
how much did it cost you to convert yours over to hydro?
