Trail Blazer Recoil Problem
Old Dec 26, 2008 | 01:43 PM
Mjones4321's Avatar
Default Trail Blazer Recoil Problem
Hey guys My polaris just bogged down and shut off. I pulled the pull start and it broke. I took the whole assembly off. I think the tab on the sping inside came out of the little holding groove or whatever. How the heck do you get the plastic wheel the rope wraps around off to get to that spring? Like i said I took the whole thing off now exposing the starter. (not just the cover) Please help me get back up and running...
Old Dec 26, 2008 | 08:55 PM
Mjones4321's Avatar
Ive tried Everything trying to get that plastic wheel off. Is it supposed to just screw off or what? Because it seems stuck. I let it sit in PB Blaster all day and still no luck.
Next Question.... Since I couldnt get the recoil starter to work. I decided to look into the Electric starter. Took that all apart too. Nothing looks broke. Its not seized or anything. I cleaned it all up and put it in there and it started right up.... Then I turned it off and tryed again... This time it just spins and doesnt ketch the flywheel. What part needs replacing??? Please help. I got this whole weekend to ride lol and cant get it started.
Old Dec 26, 2008 | 10:33 PM
Best to try to hold metal piece at back of recoil assy in a vice WITHOUT breaking the small tip that the very small spring goes on! Then plastic reel can be turned counterclockwise to loosen after that. After reel is remove the inner parts can be removed,getting down to the inner main spring. NOT a very good design,Plus I get agitated at trying to repair these myself! As far as what you are describing on the electric starter,sounds like bendix (starter drive gear) not engaging flywheel and and may need replacement. Have had several customers end up buying complete recoil assembly after working on theirs! Hope this doesn't get you down,but this recoil is a lot harder to repair than on the one piece units on the 4-strokes. Really best to have a manual if determined to repair OR let a shop be responsible if they break any thing! Good luck
Old Dec 26, 2008 | 11:30 PM
Mjones4321's Avatar
Thanks alot lol for the advice. Ill try my luck tommorow once again. But that plastic reel is like on there for good i think lol. Ive been lookin into gettin a new starter bendix on ebay..
When I examined the bendix the spring looked really worn out. Could this be the cause of my non engagement. IThe Bendix moves freely in my hands. It spins out and locks one way. And free spins the other.
Old May 5, 2009 | 12:36 PM
smc2stroke's Avatar
My 98 TB had the same problem, i just put the plastic winding spool in a vise being very careful not to break it and turn the starter dog setup with vise grips and it came apart fairly easy.
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
97TrailBlazer
Dec 6, 1999 10:33 PM
