500 polaris clutch adjustment
Old Dec 27, 2008 | 06:47 PM
dgratvbikeshop's Avatar
Default 500 polaris clutch adjustment
has anyone adjusted the spring tension on the driven clutch side using the stock spring, what holes has anyone used in it 2 or 3 and in which ones on the helix side also. Thanks
Old Dec 27, 2008 | 07:14 PM
ftwflh's Avatar
What are you wanting to accomplish with resetting the driven clutch?You can change settings to get more backshft and to compensate for bigger tires.But it gets real invlved and you need a tach to insure you dont over rev the engine or drop you rpms out of the power range.
FourWheelOverTwo
May 31, 2015 07:26 PM
Jiggypete
May 30, 2015 07:55 AM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
