tire pressure for plowing
Old Dec 27, 2008 | 10:08 PM
rr-john's Avatar
Default tire pressure for plowing
just asking around to see what people are running for tire pressure when they plow???
Old Dec 27, 2008 | 10:21 PM
DCT's Avatar
DCT
Banned
3 lbs all the way around on my stock 489's. The Sportsman's are big quads... don't want to go to low.
Old Dec 27, 2008 | 10:36 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i agree that would be a good pressure as the colder air makes them loose a little anyways.
Old Dec 27, 2008 | 10:47 PM
user493's Avatar
Moto Psycho
I air mine up to 5 psi since lowering the pressure doesn't increase the footprint on radials like it does on bias tires. They slowly lose air may get down to 3 psi before I air them back up.
Old Dec 28, 2008 | 09:42 AM
AcadGuru's Avatar
I run 3 pounds or less, but I'm running Bias plys.
It makes a big difference in the snow.
Frank is right about the radials, it helps to lower the pressure some,
but the footprint won't flatten as much as a Bias ply. 4-5 PSI is about right.
The 12" tires are also way better as far as airing down, verses the 14".
You probably want to keep at least 2 pounds of air minimum or you may unseat the beads,
unless you have bead locks.
Old Dec 28, 2008 | 04:28 PM
Dearlh's Avatar
[img]i/expressions/face-icon-small-confused.gif[/img]Never thought about tire pressure for plowing, I just keep 5 lbs. year round on my stock rawhides. I use chains most winters anyway unless I plan on plowing asphalt driveways. Traction never seems like an issue. hmmmmm.....?????
STLyamwar
Jul 25, 2020 04:44 AM
Erick J. Edler
Sep 20, 2015 05:51 PM
ylomnstr
Sep 4, 2015 05:02 PM
Erick J. Edler
Aug 29, 2015 01:32 PM
baysport
Jul 23, 2015 11:37 AM
