whats up with this oil coming out the crank into the airbox????
Old Dec 28, 2008 | 01:05 PM
NoJoKe23232323's Avatar
Default whats up with this oil coming out the crank into the airbox????
it happened to me again so i just took the crank case hose and disconnected it so it wont spit out oil into the air box but how can i get this to stop?? just put in an 06 carb in my 03 400ex is that bad??? its running fine but it redlines to much like it wants more. my jets are jetted to an aftermarket exaust and im alll stock is this also bad?? please help me
Old Dec 28, 2008 | 04:02 PM
cherokee99's Avatar
1. if you are getting oil spitting into the air box, its probably overfilled. drain the oil and replace with a know correct amount, about 1.9Qts with a filter change, so mabe 1.7Qts if you dont change the filter.
2. sounds like you are runnign rich. is there a diffirence between the carbs from an 03-06? you should jet back to stock settings because you are running the carb on a stoch mechine, which is probably way too rich for the mechine
Old Dec 28, 2008 | 07:22 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Isn't this a duplicate post????
http://forums.atvconnection.co...tid/8/threadid/557350
Most likely you rings are shot, and the blowby pressure has nowhere to go but out the breather....and it carries some oil with it. Unless you have just way overfilled on your oil?????
Old Dec 28, 2008 | 08:36 PM
cherokee99's Avatar
ya its the same questions from an earlier poast... after i saw the earlier one im thinkn rings as well. or way overfilled still
Old Dec 28, 2008 | 11:39 PM
yep i guess it wwas my rings causee now alot of oil comes out of the crank case and it lost torke and just shut off?? how do i jet it to stock settings please tell me? and if i change all my gaskets should i be fine??
Old Dec 28, 2008 | 11:46 PM
are rings gaskets?? is that what you mean when you say rings?
Old Dec 29, 2008 | 12:00 AM
thejoker1290's Avatar
no rings are ont the piston. there metal
Old Dec 29, 2008 | 09:56 AM
Red Rider
Read about rings here: http://www.dansmc.com/MC_repaircourse.htm
Take it to an experienced mechanic, who can diagnose it first hand!
Also replace the valve guides while you are at it. You any need to rebore it, etc., etc. Might trun into a major rebuild!
Old Feb 27, 2009 | 01:50 PM
-Gary-'s Avatar
Sorry, to bump an old thread but I cam across this and have actually experienced this 1st hand with my 400ex.
The compression was great, it never burned oil but the vent hose from the tranny to the airbox would shoot oil at WOT and nearly fill the airbox.
I checked the compression again after another ride and the result was the same ...airbox full of oil. I ended up taking that hose from the tranny and making a crude air/oil separator under the headlight that would take the excess oil and dump it in the valve cover. Then I took the blow-by from the air/oil separator through a PCV vanve back to the airbox. That solved the problem.
I found out later that there is a seal between the tranny and the block that was bad....
No bad rings.
Just a simple seal bad.
Too bad I had already sold it...
slowgsxr97
Mar 18, 2022 03:40 AM
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
ghost civic
Jul 20, 2015 12:36 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
