Indy 500 engine problem
Old Dec 28, 2008 | 03:44 PM
double19204's Avatar
Default Indy 500 engine problem
Alrite, I was driving my sled , which is a 2000 indy 500, n i was following my dad n my engine started to bog n couldnt climb over 40mph even when it was pinned.It started to act up when i was on the trail for an hour or so. N then i would shut it off n wait a couple of minutes. Then started it back up n then i would have full power for awhile until it started to act up again. When we got home we sprayed carb cleaner by the crank seals n the whole engine started to bog down and almost clunk out. N then we just let it sit for now
Anybody got any ideas whats wrong with it?
Old Dec 28, 2008 | 04:12 PM
blkedoutsprtsman's Avatar
im not 100% sure but you may wanna reroute this topic to a snowmobile forum for additional help.
Old Dec 29, 2008 | 12:20 AM
95wolv's Avatar
Sounds like your found the problem, if you spray carb cleaner near the crank seals and the motor runs different, you have a vacuum leak at the crank seal, that is why it runs good cold, when it warms up, you start sucking air, and lean out. Replace those seals, or soon you will be replacing melted pistons.
Old Dec 29, 2008 | 04:42 PM
tv4fish's Avatar
Or -- You already may be experiencing "engine seizure" - When the pistons expand due to running too lean (as in too hot), the friction will slow down the rpms - when the pistons cool and "shrink", off you go until they get too hot again.
Old Dec 29, 2008 | 04:53 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
pull out your pliugs and take a look at them and tell us what they look like and we can go from there. if you sparayed starting fluid near the crank seals and the engine reved up then i would say you have a bad crank seal. maybe the carbs are dirty as well since you said ran good for a while. theres a whole list of probelms it good be so start simple.
scaldwellk
Jun 19, 2015 05:08 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
RoostKing
Dec 17, 1999 07:26 PM
