plow pressure
Old Dec 29, 2008 | 03:48 PM
rr-john's Avatar
Default plow pressure
how much pressure do you think the plow is putting on the atv 200 lb or much more like 1000 lb. im working on a plow angle kit
Old Dec 30, 2008 | 02:40 AM
user493's Avatar
Moto Psycho
Pressure down, or backward? It's a lot of pressure backward when I run into snowbanks.
Old Dec 30, 2008 | 11:35 AM
BigBros_Farmtoys's Avatar
Pressure pushing back on the blade is going to be a lot.
Running into Snow banks exerts bunches of pressure but that may be even across the blade.
With an angled blade you will exert more pressure on that center pivot point.
i.e. 60" blade if you exert 100 lbs of force at the forward edge only then that is multipled to approximately 250lbs of force at the center pivot point.
It seems that most of the remote pivots I have looked over have a locking system similar to the existing blade lock or they manipulate the blade lock to unlock it, move the blade and then lock it into the appropriate angle point.
That puts the holding force back on the blade mechanics rather than the remote tilt cable/motor.
hth.
Alex G.
Sep 11, 2017 11:38 PM
2many2ride
Sep 27, 2015 04:35 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
