Need Help with Tires
Old Dec 29, 2008 | 09:07 PM
bowhnter78's Avatar
Default Need Help with Tires
I have a 2002 kvf 650 prairie and need to know what is the largest tire size i can do with out having to do lift or mods to wheeler. would like to go with 27 10-12 frnt & 27 12-12 rear on stock rims.
Thanks for any info
Old Dec 29, 2008 | 09:51 PM
smitty800's Avatar
27 should work just fine and you may be able to go a little bigger. we had a big bear 400 and put 27's on it with no lift or anything.
Old Dec 29, 2008 | 10:18 PM
bowhnter78's Avatar
Thanks for your help I'm More worried About the width the Stock tires are 25 8-12 front & 25 10-12 Rear before I dont want to order the tires and have problems from rubbing.
Old Dec 29, 2008 | 11:07 PM
smitty800's Avatar
type in brute fore tires on the search bar on here and read some of those. from what i read i would only go with 27's if they are mudlites because they are lite. anyother tire it sounds like to me from what ive read you will need a better clutch kit. also i would say that 12 inch wide is a little big go with 10inch or llinch i would go with 10 wide on front and back
Alex G.
Sep 11, 2017 11:38 PM
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
