trx450er 06 after a week will not start
Old Jan 1, 2009 | 07:29 PM
tntforever1's Avatar
Default trx450er 06 after a week will not start
i have a 06 trx450er all stock. if i run it every day. no problem if i let it sit for a week it will not start. the only way is to pull it . after you pull start it i have no problem. even the next day it will start right up but if i let it sit for a week i have the same problem and it will not start..
Old Jan 1, 2009 | 07:48 PM
dgratvbikeshop's Avatar
try having the valves checked and make sure your fuel is not leaking out of carb and into crank case over that week of setting.
Old Jan 1, 2009 | 07:59 PM
cherokee99's Avatar
if you ave haveing to pull start it thats more of an electrical problem. use a volt meter and see how much juice you battery has aftera week of setting. if its less than 12v you have a weak battery, and it needs to be replaced. really the best thing is to not depend on the pull starter, thats why you bikes comes with electric start lol.
Old Jan 1, 2009 | 09:41 PM
nas3car8's Avatar
have you done a compresion check, my buddies did that and had to put new rings in it.
Old Jan 1, 2009 | 09:53 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
It sounds to me that you have a weak battery.
The battery on the 450er is very small and runs dead quickly while trying to start it.
Old Jan 2, 2009 | 06:13 AM
the battery is fine it will turn like hell bu will not fire up
Old Jan 2, 2009 | 06:19 AM
i'll have to check that. thanks
Old Jan 2, 2009 | 10:09 AM
Stoopidbot's Avatar
Can I hear your whole start up procedure? On my 07 450ER I pump the gas about 7-10 times, with the choke on hit the start button. DO NOT TOUCH THE THROTTLE WHILE TRYING TO START. You will flood it out.
Old Jan 2, 2009 | 11:29 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Sounds like a gummed up pilot jet. That makes it lean and that doesn't favor a cold start. Once warmed up, it gets by but you will still be a little lean overall.
