Leaking Carb,
Old Jan 1, 2009 | 08:48 PM
gugonga's Avatar
Default Leaking Carb,
My 3-wheeler as been sitting since last spring, and the carb is dripping? Is it dirt , stuck float, ? What would you guy recommend, Fresh gas and tap on the side of the carb, put an half hour , hour of driving on it ? Any information would be appreciated ~ (out of the small black tubing)
Old Jan 1, 2009 | 09:17 PM
cherokee99's Avatar
well one, its not a good idea to store anything for a length of time with the gas on. my top guess would be a leaky O-ring onthe bowl of the carb, due to age. get a gasket kit and replace the o-ring. next it may be a stuck float, if the o-ring didnt work. see if the float is water tight but removeing the float pin and holding the float under water. inspect/clean fuel regulator that the float ataches to. after that then mabe you have some hoses leaking ect..
Old Jan 4, 2009 | 07:54 PM
pauley501's Avatar
i would say its stuck floats or needle valve if you take the bowl off the carb and run the petrol trough it and push the float up with your finger and make sure it stops the flow of petrol if not take out the needle valve and clean it put it back in and try again
Old Mar 6, 2009 | 06:20 PM
Jeff_85200M's Avatar
float is stuck... typical for a honda or yamaha... take your carb off and clean it.. when u put it back together.. adjust it up again.. should purr like kitten!
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
