1995 Warrior new to me
Old Jan 2, 2009 | 12:16 PM
Racingbrat's Avatar
Default 1995 Warrior new to me
Just wanted to say hello to everyone ,just got this quad new to me trying to find info good or bad Thanks.
Old Jan 2, 2009 | 12:37 PM
Politically Incorrect's Avatar
Warriors are good quads for the most part. They have been around for a long time and alot of people have had fun on them. The worst thing about them is they will rattle there bolts out pretty bad. Anytime you take a bolt off, use Locktite to prevent this from happening. They also break the upper engine mounts, and the lower engine bolts will work loose. Also keep a check on the frontend a-arm bushings, wheel bearings, and ball joints. Keep them greased. Keep the chain tight enough so that it doesn't jump off and bust the casing. Other than that, fill it up with gas and change the oil and you're ready to ride!
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
wendal
Sep 15, 2015 01:50 PM
