Winch Question
Old Jan 2, 2009 | 02:04 PM
budedm's Avatar
Default Winch Question
I can't see buying a 12V power winch when I think a hand crank boat pulling winch will work just fine. You know the kind that mounts on the front of a trailer to pull the boat in from the water? Is there any problems with my idea? I only have small sport ATV's so why should I buy an expensive powerfull heavy winch? Not only that but my 87 250X doesn't have a battery.
Old Jan 2, 2009 | 02:16 PM
SuziOzark's Avatar
No Battery=No Winch.
All winches require an ATV with a battery to supply power to the winch.
That hand crank is not a bad idea!
Old Jan 2, 2009 | 06:52 PM
Phlogiston's Avatar
Other than being Butt-Ugly it would work.
You can put a battery on a 250X. I put one on my 250R. I was tired of the lights going out at night as I slid around corners with the back end locked up. As I recall someone even made an electic start for the 250X - at one time.
Russ
Old Jan 3, 2009 | 10:16 AM
sporter's Avatar
Where can you mount the boat winch that will allow you to turn the crank handle?
Old Jan 3, 2009 | 10:32 AM
tunneldanny's Avatar
Bass pro sells a hand atv winch with a rachet handle, you dont even have to mount it, check it out.
Old Jan 3, 2009 | 10:43 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Black Max Ratchet Winch!
http://www.nvginc.com/newwinch.htm
Old Jan 5, 2009 | 08:48 AM
budedm's Avatar
Now THAT is what I need. Thanks for the link.
Old Jan 5, 2009 | 05:05 PM
hondarider94's Avatar
it will work, but if u think about it the only reason its easy in a boat is cuz the boat is IN water... now try to pull a stuck atv out with it..
ylomnstr
Sep 22, 2015 12:19 AM
Rick Van Matre
Sep 11, 2015 11:52 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
ylomnstr
Sep 4, 2015 05:02 PM
