Fuel Injector Cleener?
Old Jan 3, 2009 | 03:55 PM
Polaris800Touring's Avatar
Default Fuel Injector Cleener?
Has anyone ran any injector cleener threw there efi machines yet? I just want to be sure before i do it that it dosent cause any problems. I use lucas in my truck and i was thinking about putting some threw the 800 as well. thanks
Old Jan 3, 2009 | 05:26 PM
Koerbs's Avatar
You should never need to run a cleaner in your machine, it won't ever see enough pulses in a machines lifetime to need a cleaning.
Old Jan 3, 2009 | 05:31 PM
OIown12's Avatar
I use the Polaris Carbon Clean. Came with the fluid change kit so I figured I'd use it. I use Lucas in the cars and trucks.
Old Jan 3, 2009 | 05:56 PM
DCT's Avatar
DCT
Banned
I don't have EFI and I still run Lucas Fuel Treatment in every tankful. I would do the same thing if I had EFI. You never know the quality of gas you are getting. The Lucas stuff will keep the entire fuel system clean, and lubricate the top cylinder.
I wouldn't use a strong additive on a regular basis. I plan on running some Sea Foam (recommended in this forum) once or twice a year for a stronger cleaning.
Old Jan 3, 2009 | 06:06 PM
HIGHOCTANE's Avatar
I use a little Seafoam or Lucas occasionally as a preventitive measure...doesn't hurt a thing. It isn't a miracle fix for a poorly maintained machine but with the crap I have seen come out of my vehicles fuel filters if they can help keep it a little cleaner it's reason enough for me...todays gasolines are not as clean as you would think. Not to mention it helps keep the carbon build up in the combustion chamber under control. Important on a machine that spends alot of time idling and at lower RPMs like mine
Luckily they put an inline fuel filter on the XP...
As Dave said,the Seafoam is more of a cleaner and the Lucas a mild cleaner but more of a lubricant...
Old Jan 3, 2009 | 06:20 PM
Koerbs's Avatar
Seafoam is good practice for keeping the fuel fresh in the off season and does lubricate the injector.
Old Jan 3, 2009 | 11:15 PM
cherokee99's Avatar
seafoam all the way!!! took a small engines class and the instructor used all the hardware store products. seafoam made the most improvement to fuel injector preformance by 20% over the next best treatment (said the diagnostic computer) so that is what i use and recomend for a cleaner in all engines
Old Jan 3, 2009 | 11:21 PM
user493's Avatar
Moto Psycho
Seafoam sounds like great stuff. I should get some too. Do they have it practically everywhere like STP and Sta-Bil?
Old Jan 3, 2009 | 11:36 PM
Ruggo's Avatar
HighOctane mentioned a fuel filter..... is there a fuel filter on the XP's that need to be cleaned? I suspect it doesn't take much to clog an injector.
Old Jan 3, 2009 | 11:37 PM
DCT's Avatar
DCT
Banned
<div class="FTQUOTE"><begin quote>Originally posted by: jumbofrank
Seafoam sounds like great stuff. I should get some too. Do they have it practically everywhere like STP and Sta-Bil?</end quote></div>
I picked up a can at AutoZone for 9.50 or something like that. Then I saw it at Wally World for around 6.50. Picked up two more cans... one for my son.
