05 700 EFI
Old Jan 3, 2009 | 05:16 PM
Outback31's Avatar
Has ridden Rockhouse and Bearwallow trails.
Default 05 700 EFI
My buddy noticed coolant running out of his flywheel cover bolt's,ie, gear stator housing bolt's when changing jis starter. Is this a sign that he need,s a new Water Pump or seal?
Thank's for any replie's in advance.
Old Jan 3, 2009 | 10:58 PM
Default 05 700 EFI
Wipe it down and see if leaking from weep hole under water pump cavity OR water pump gasket or seeping from radiator hose! If from weep hole,new seal is needed AND stator inner cover has to be removed to replace seal!
Old Jan 3, 2009 | 11:54 PM
Outback31's Avatar
Default 05 700 EFI
Thank's OPT, U R the Man, we like wrenchin on them too , rather than buying new all the time.
Thank's for the help
