Trail Boss valve cover
Old Jan 3, 2009 | 11:39 PM
brainpause's Avatar
Default Trail Boss valve cover
I have read almost all the valve adjustment topics here, but none covered my issue.
A little over 2 years ago, I did a valve adjustment on my 2000 Trail Boss.
After I did this adjustment a couple of years ago, seems it ran fine. This ATV doesn't see much service. Well, about a year ago, I started it up, and went about my business in the barn, letting it warm up, and idle. I turned around and the barn was filling with smoke. I ran down to it, and it was pouring oil onto the hot exhaust. I couldn't see what was wrong, but I was afraid I had a cracked block.
Fast forward to now. I am just now getting to it (baby, move, same job but moved office, etc etc). I got it disassembled, and the valve cover was just sitting there, as if I forgot to put it back on.
Now, mind you, I didn't forget to put it back on. After all, I rode it several times after the valve adjustment.
What could have made the valve cover pop off? I'm pretty sure I got it on good, but I guess it's possible it was cross-threaded or something.
Could I have done the valves too tight or too loose and some exhaust pressure caused it to blow off?
What's going on? Help!
Larry
Old Jan 4, 2009 | 09:23 AM
Kerbbirds's Avatar
Must not of gotten the bolts tight, there is a tourqe spec for them, might try a little thread locker.
Old Jan 4, 2009 | 10:07 AM
brainpause's Avatar
There are no bolts. It's just a cheap plastic screw-on cap that goes over the valves.
I put it back on last night after I posted the above. It went on tight. I see no damage, but I still wonder if a compression/fire stroke somehow blew it off.
Larry
Old Jan 4, 2009 | 11:11 AM
ftwflh's Avatar
I think I would be replacing that valve cap.Heat colud have weakend it and let it work off
Old Jan 23, 2009 | 06:43 PM
brainpause's Avatar
OK, so I did the valve adjustment carefully and replaced the valve covers. I started it up and it sounded like crap. But it has sounded like crap for a long time.
I let it warm up and ran it up and down the driveway a few times. It sounded much better after warmup. I can't see any exhaust leaks, but that doesn't mean they don't exist. The exhaust system is original (from September 1999). But I think the crappy rattly sound is more internal.
Any thoughts?
Larry
Old Jan 24, 2009 | 08:11 AM
eggenz7's Avatar
does it have a timing chaing. have you checked the tensioner to see if its loose?
Old Jan 24, 2009 | 01:26 PM
brainpause's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: eggenz7
does it have a timing chaing. have you checked the tensioner to see if its loose?</end quote></div>
No, it doesn't have a timing chain. At least not that I can tell.
Larry
Cole Hadden
Jun 15, 2025 09:05 AM
Gnuters
Jul 19, 2015 10:03 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
yambam13
Jul 4, 2015 01:49 PM
