Big Bear random sputtering and backfire
Old Jan 4, 2009 | 09:42 AM
Jeepsterbrad's Avatar
Default Big Bear random sputtering and backfire
my 02 big bear has been sputtering and sometimes backfiring on me randomly. I completely cleaned the carb and changed the plug and still didnt help. Also thought it could be a bad coil so i sprayed the coil and wire with soapy water but it didnt kill the motor so im suspecting that is still good, could this be a bad CDI? seems like it will sputter worse when under a load
Old Jan 4, 2009 | 03:06 PM
cherokee99's Avatar
did you remove and clean the pilot jet? that can cause sputtering. use a volt meter and ohm the CDI, see if its any good
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Brandon400
Sep 7, 2015 12:20 PM
Elkaholic
Sep 6, 2015 02:44 PM
Slagpolaris
Sep 5, 2015 09:41 PM
