what's the best pipe for a lakota
Old Feb 6, 2001 | 10:28 PM
hondaboy5's Avatar
will I have to rejet anyone tell me how to rejet is it hard is it a due it your self
Old Feb 9, 2001 | 09:56 AM
mojaveaddict's Avatar
Choices for Lakato pipes are limited. I like the Supertrapp ids 2. Get the race series, not the quite series. Do not buy it from Rocky Mountain ATV. They are good to deal with and have great prices but do not sell the race series. All you need to do is change the main jet. This is not hard to do, but do not take the carb all the way out leave the choke cable connected to the carb and take everything else loose and work the carb to a position the you can remove the bowl screws and get the bowl off. You may have to remove some of the ties that hold the choke cable to the frame to get a little slack. If you take the choke cable loose you will be cursing when you try to put it back on. Then replace the main jet with 1 size larger. 1 size up is usually about right, ride it for a little while and look at the spark plug. If it is burning very white go up to the next size and repeat. Plug should have a slight tan color. You should not need more than 2 sizes larger.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
