04 Grizz start problem
Any help with this would be awesome, YFM 400 Grizz, 04'. Rode yesterday in a fair amount of snow. Went to remove from trailer, and as I shift (foward, neutral, reverse), the indicator lights do not show on dash. Auto shift 4x4 is lit when engaged. Machine will not turn over with starter switch, and will not run when jumping starter, as if kill switch were on. searched problem in archive forum, only found shifter safety switch locations, and Park brake problems. On this model, there are no wires to or from shifter housing. Had reverse, and neutral indicator before issue. The linkage to trani is working,as it does shift; cable from foot pedal is releasing gear selector in shifter housing.
