cant throttle up with clutch pulled
Old Jan 8, 2009 | 01:50 PM
Doc_Loveless's Avatar
Default cant throttle up with clutch pulled
i have a 98 yamaha warrior. When I pull the clutch in I can't get my bike to give me any throttle. For example if I have the clutch pulled in and I push the throttle to rev the engine it just stalls out or back fires through the tail pipe. If I let the clutch out almost all the way about 95% I can then give it throttle. I think this is an electrical problem.
Which brings me to my next question. Can you remove all the electrical componets from the bike and it still run. I meen I can wire a switch for the head lights but, I dont see any wiring for the engine except the spark plug. So in theory I should be able to remove all of this stuff right?
Thanks for the help.
Old Jan 8, 2009 | 02:27 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
What about in gear and riding? Does it run ok?
Old Jan 8, 2009 | 03:05 PM
Politically Incorrect's Avatar
Probably the parking brake sensors mounted on the clutch perch are bad. Best thing to do is to bypass that JUNK.
Old Jan 8, 2009 | 07:33 PM
yea it runs fine when i ride it, i just have to let off the fuel shift and then let off the clutch and then give it gas. which is what i should do anyway, but when your ripping through gears racing down a path it slows you down not being able to throttle up as you are letting go of the clutch.
I will try to bypass the senosors any idea how I might do this. You said they are on the cluthc handle. I tried disconecting the to electrical wires running into the clutch but that just stops me from being able to use my throttle all together. should i take apart the clutch handle housing and jump it in there?
Old Jan 8, 2009 | 10:37 PM
Raptor450's Avatar
There should be 2 sensors, my Warrior had 2 black wires going to each sensor. Can't remember exactly how I did it, but seems like I cut the wires off of the sensors and the 2 wires from 1 sensor had to be tied together permanently (closed circuit) and the 2 wires from the other sensor had to be loose from each other permanently (open circuit). I just tried different combinations until I got it right, you got a 50/50 chance to get it right the 1st try. Heat-shrink butt splices work the best for a water-tight seal when joining or capping off the 2 wires, you can get them from any auto parts store.
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
Jun 2, 2019 07:25 AM
200es
Jul 10, 2015 09:09 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
