Overhaul Kits?
Old Jan 10, 2009 | 10:50 PM
500H.O.'s Avatar
Default Overhaul Kits?
Anyone know were I can buy a complete overhaul kit for my 2003 sportsman 500ho?
Old Jan 10, 2009 | 10:54 PM
Koerbs's Avatar
Did it blow up?
Old Jan 10, 2009 | 10:58 PM
500H.O.'s Avatar
no, it's running but smoking alot
Old Jan 10, 2009 | 11:15 PM
eggenz7's Avatar
you probably just need to either rering it or bore it and put the next size piston in it
Old Jan 10, 2009 | 11:16 PM
500H.O.'s Avatar
any suggestions on were to buy parts?
Old Jan 10, 2009 | 11:17 PM
Koerbs's Avatar
What he said ^^^^^^
Old Jan 10, 2009 | 11:21 PM
Spdecat's Avatar
If it only has 1100 miles you would not think that it needs a rebuild already maybe something else is going on .
eggenz7's Avatar
the best way to get it done is pull the cylinder off and take it to a shop to see if it can just be cleaned up and reringed or if it needs to be bored. if it needs to be bored get the needed size from them and order a wiseco piston. ebay is probably the best bet on that. if it just needs rings you willl have to go thru dealer because it is a oem piston in there
Old Jan 10, 2009 | 11:22 PM
Koerbs's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 500H.O.
any suggestions on were to buy parts?</end quote></div>
Polaris dealers have that stuff.....
Old Jan 14, 2009 | 11:04 PM
500H.O.'s Avatar
My dealer told me they would rebuild my engine for about $475.00. That's boring the jug, new piston, rings, rist pin, and checking the head / replacing valve seals if needed. Is this a good deal? I thought it sounded pretty cheap.
