Which Winch Works?
Old Jan 11, 2009 | 03:20 PM
GrayGore's Avatar
Default Which Winch Works?
I've got the Polaris 3500# winch (wanted the synthetic rope), and I haven't had any trouble with it. Now I'm seeing lots of posts on bad Polaris winches, and I'm wondering about it. If you've had problems with a polaris winch, can you please post what model/size/age or whatever so we can figure out if it's a particular model that's giving trouble?
Thanks
Old Jan 11, 2009 | 03:38 PM
HIGHOCTANE's Avatar
I've had 2 Polaris 3500# winches on 2 machines and niether have given any trouble..they don't sound as smooth as a Warn but so far so good. Granted I don't use mine very often but when I do I work it hard..usually dragging HEAVY logs .. both with and without a pulley/****** block... most times I use it it is pretty much a straight hour of hard pulling dragging logs on to trailers and it never misses a beat...so far
I think the 3500# is the only one I have't heard of problems with..other than the crapy remote recepticle cover that is too big..I made a wire insert for mine to keep it on..
Watch now that I have said that next time I go to use it it will crap out,lol..
Old Jan 11, 2009 | 05:35 PM
mtpockets's Avatar
2500 lb Polaris winches are the trouble ones. Right out of the box brand new.
Old Jan 11, 2009 | 06:31 PM
*5 J's*'s Avatar
I haven't had issue with the 3.0 other than the recepticle cover as HIGHOCTANE mentions. I solved that by putting a velcro strap around it.
Old Jan 11, 2009 | 08:35 PM
upnort's Avatar
Add another to the Junk chinese polaris winch club. 1st one lasted maybe 3 rides, then winch quit. Would make noise & showed 12 volts across terminals so not contactor. Still under warranty so dealer swapped out. 2nd has been doing fine for almost 3 years now. It has seen alot of use too, pulling out of mud, plowing. This was from winter of 2006. 2500 #. Thought was in trouble when looked at bottom of box & saw "MADE IN CHINA"
Old Jan 11, 2009 | 09:06 PM
blkedoutsprtsman's Avatar
so far so good...i have polaris 2500lb winch.
Old Jan 12, 2009 | 08:07 AM
mtpockets's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: blkedoutsprtsman
so far so good...i have polaris 2500lb winch.</end quote></div>
What color is your pull tether? Red or Orange?
Old Jan 12, 2009 | 08:12 AM
MrMarty51's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: mtpockets
What color is your pull tether? Red or Orange?</end quote></div>
Mine is red.
Does it make a difference???
Old Jan 12, 2009 | 12:53 PM
mtpockets's Avatar
ORANGE- Has "Polaris" written on it. That's the pure junk Chinese winches.
Red- Has "Warn" written on it. That's the quality, trouble-free one that you want hanging off the front end of your ATV.[img]i/expressions/face-icon-small-smile.gif[/img]
Both are (or were offered) by Polaris. Unfortunately I was decieved into buying the junk one. (as were many others).
I have since changed to the Warn.
Old Jan 12, 2009 | 11:54 PM
MrMarty51's Avatar
Red- Has "Warn" written on it. That's the quality, trouble-free one that you want hanging off the front end of your ATV.[img][/img]
Thanks for the headsup.Ipurchased My machine used and the winch was already in place but it sounds like the previous owner did it right.
I have since changed to the Warn.</end quote></div>
