Outlander 330 lurching
Old Jan 11, 2009 | 09:08 PM
lzydaze's Avatar
Default Outlander 330 lurching
I was testing a 2005 Outlander 330. Everything seems okay but there is some lurching when taking off. I had to rev. the engine a bit and the clutch seemed to engage abruptly. Is there an adjustment or is this normal?
Thanks
Old Jan 11, 2009 | 10:40 PM
TorkMonster's Avatar
Not sure on the 330 how the clutch is setup.. But it sounds like maybe belt problems...
Open CVT and take a look..
Also, though as I said, not sure on the 330, but engagement IS tunable on most of them.. Primary spring change will change engagement would be a little smoother with a lower stall spring, OR lighter weights.....
Old Jan 12, 2009 | 11:43 PM
lzydaze's Avatar
I should add that this unit had very low hours, like maybe 25 hours so it's probably not wear, maybe an adjustment?
bigred20653
Oct 2, 2015 10:05 AM
panicmanic
Sep 28, 2015 12:59 PM
bigred20653
Sep 19, 2015 02:11 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Gtsordo
Jul 22, 2015 01:27 PM
