2000 kodiax disc brake ?
i just put new rear pads on mine , it dont seems to stop at all. i even bleed the brakes and no luck,
i can see the pads squeeing on the disc and i cant turn it by hand ,but when bike is going no matter how hard i push on the brakes it wont stop fast, its still like just letting the the bike slow down by engins braking , the fronts work great .
You could still have air in the line, brake cylinder or master cylinder. Did they squeeze hard before you replaced them? If so did you do anything to "loosen" them before you replaced the pads? If you didn't adjust the cable at all then I would guess that there is air in there somewhere.
oliveiracarlos
Sep 7, 2015 03:39 AM
