Yamaha blaster
Old Jan 11, 2009 | 11:20 PM
polarispredator7678's Avatar
Default Yamaha blaster
hey i had a broken clutch so i replaced it and its wicked hard to pull in is that normal and if not what kind i do to make it easier to pull in?
Old Jan 11, 2009 | 11:45 PM
brian 68's Avatar
check your cable, unhook it does it pull back and forth easy? did you put heavy duty springs in , if so you might try a aftermarket lever , but heavy springs pull harder, also who installed the clutch, was the cover, arm installed, per spec's
Old Jan 12, 2009 | 11:09 PM
BEC300ex's Avatar
hey mine was tha same way and i sprayed wd-40 down tha cable while it was pulled in all tha way and now its easier to pull.
Old Feb 12, 2009 | 12:02 AM
Blaster6678's Avatar
Just curious, but how fast does your blaster top out at?
Sep 17, 2015 03:06 AM
nastyblaster100
Sep 13, 2015 01:19 PM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
