help on 250x chain adjustment?!
I believe if your standing behind the quad its the right side. There should be notches that you can twist the carrier to tighting the chain. Its been a little since I did it.
Loosten the two 6mm allen bolts on the back side of the axle. The take the same allen wrench and slip it into one of the slots on the left side of the carrier and push or pull to rotate the axle. The axle rides in bearings that are not in the center of the carrier so when you rotate it, the axle gets further or closer to the engine.
