help on 250x chain adjustment?!
Old Jan 12, 2009 | 12:03 AM
250Xftw's Avatar
Default help on 250x chain adjustment?!
How in the heck do you adjust the jain on these things lol. I assume it has to be inside the axle thing on the back. can anyone give me some specifics
Old Jan 12, 2009 | 01:55 AM
87250xman's Avatar
On the rear axle carrier.
Old Jan 12, 2009 | 01:58 AM
250Xftw's Avatar
is it inside or what?
Old Jan 12, 2009 | 02:01 AM
87250xman's Avatar
I believe if your standing behind the quad its the right side. There should be notches that you can twist the carrier to tighting the chain. Its been a little since I did it.
Old Jan 12, 2009 | 02:04 AM
250Xftw's Avatar
hmmm, all thats there are a few hex head bolts. 2 on the top center of the axle and 1 lone bottom center one?
Old Jan 12, 2009 | 02:08 AM
87250xman's Avatar
P.M me your E-mail and Ill try to get a picture to you.
Old Jan 12, 2009 | 02:15 AM
250Xftw's Avatar
ok
Old Jan 12, 2009 | 02:29 AM
250Xftw's Avatar
let me know when you send it because i just deleted some stuff out of my email
Old Jan 12, 2009 | 09:40 PM
budedm's Avatar
Loosten the two 6mm allen bolts on the back side of the axle. The take the same allen wrench and slip it into one of the slots on the left side of the carrier and push or pull to rotate the axle. The axle rides in bearings that are not in the center of the carrier so when you rotate it, the axle gets further or closer to the engine.
Old Jan 12, 2009 | 09:42 PM
87250xman's Avatar
I keep say right when i ment left. sry
