Throttle Sticking
Old Jan 12, 2009 | 01:53 AM
87250xman's Avatar
Default Throttle Sticking
My friend has a 1997 Artic 300 4x4. When he has it out in cold weather for about a 1hr or so the throttle gets stuck. What could be causing this issue.
Old Jan 12, 2009 | 10:39 AM
mudslinginfool's Avatar
Does it in the Mud!
is water invalved? Like riding in the creeks, snow,rain? when it snows here,then i put my bike away and try to ride the next day sometimes its frozen. may need to shoot some lude down the throttle cable and on the carb to keep it from freezing. my 4wd would do the same if i rode through a creek.
Old Jan 12, 2009 | 03:15 PM
87250xman's Avatar
As long as its cold outiside it freezes no matter where your ride.
Old Jan 14, 2009 | 07:15 PM
swampyjunior's Avatar
I had a similar issue with my TRV. THe throttle would be stuck if the temps outside were below freezing. I tried lubing it with a special cable attachment thing, cleaned the linkages, re-routing the cable to make sure it was not pinched and in it still did it.
I replaced the cable and I have had no other issues since. It got to be a real pain to let it sit and warm up and thaw out. Plus it would get pig headed and die and you could not give it a little throttle to keep it running. So give the cleaning, lubing a try first.
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
