Knock Knock
Old Jan 17, 2009 | 12:20 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Default Knock Knock
Hi there, new to the forum, lots of good stuff in here. I'm new to the polaris brand and love it! Just bought a 02 325 magnum 4x4 and it runs great but once I got it the garage I noticed at low idle I can hear kinda of a dull knocking/pinging sound from the engine. As I increase the rpm's in nutreul the sound seems to speed up then blend in to engine noise. Is this normal with the polaris? I thought maybe somthing was loose underneith and was vibrating but I can't find anything.
Old Jan 17, 2009 | 01:00 AM
JAB722c's Avatar
Default Knock Knock
I had a 400 sportsman now I have an 700 and I never heard that in any of the machines
Old Jan 17, 2009 | 09:51 AM
rancher55's Avatar
Default Knock Knock
Try a little Lucas oil (upper cylinder lubrication) in your gas or you could try Seafoam gas additive. Both work well. You can get both at Wally World.
Some of the gas you get now days is pretty crappy IMO![img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 17, 2009 | 10:05 AM
ftwflh's Avatar
Default Knock Knock
The 3 things that cause the knock are bad primary clutch buttons,weak pull start spring,or on the 325 a crank bearing going bad.
To check the clutch pull it off and start it up if the noise quits rebuild the clutch.Pull starter use a wooden handle or mechanics stethoscope and listen to the recoil cover.The rod will be harder to isolate.
Good luck
Old Jun 28, 2009 | 10:06 AM
IamBIGGUN's Avatar
Is there an easy way to pull it off? Do I need to purchase any special tools?
Kevin
Old Jun 28, 2009 | 10:15 AM
ftwflh's Avatar
Kevin
You will need a clutch puller.If you plan on keeping a Polaris it is a must have tool that will be used a lot
Old Jun 28, 2009 | 10:19 AM
IamBIGGUN's Avatar
Is there a part number for the puller? I'm assuming it's specific to primaries.
Kevin
Old Jun 28, 2009 | 11:59 AM
ftwflh's Avatar
All Polaris primary clutch pullers are the same even the sled pullers
Old Jun 28, 2009 | 04:13 PM
IamBIGGUN's Avatar
Cool. Thanks!
Old Jun 28, 2009 | 07:08 PM
danparkcityut's Avatar
We have an '00 325 Magnum. We bought it new, and I've not noticed any odd noises from day one. Sorry I can't be of more help...
Tomtom86
Aug 7, 2024 07:40 PM
01ssls1
Sep 22, 2015 06:50 AM
merryman
Sep 19, 2015 03:15 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
