Quick Noob oil question for warrior 350
Hey guys,
We have some snow here in New England and I'm dying to take the quad out. Checked the oil in advance and it was pretty low. The only place open in my town was a hardware store which i hate because they never have what I'm looking for. Long story short, will this oil work for a temporary solution.
Pennzoil Premium Plus marine 2cycle (outboard synthetic blend)-It says it recommended for premix and injector systems, TC-W3 oils.
Also have a half quart of mobil 1 synthetic motor oil which I could use temporarily in 0w-40....
Which should i use? Ill buy the right stuff this week, just need a temp. solution.
Thanks for any help!
all motor oils are not a good thing to use on atvs since atvs use wet clutches, any oil that is JASO approved is ok to use which will most likely be a motorcycle only oil, to be safe i would try and find some diesel oil in that hardware store like rotella or ursa most diesel motor oils will work fine in atvs since diesel have wetclutches, try to find Rotella 15-40 i still use the stuff today as we speak on my warrior and it works great,make sure whenu check the oil its on the most level ground you can get it on as possible and that the engine is warmed up a little.
God no do not use that oil, 2 stroke oil is NOT motor oil and will do absolutely no good but ruin your clutch and engine. Get a motorcycle wet-clutch safe oil. Yamalube, Valvoline Motorcycle, BelRay, Amsoil and Lucas are all good choices
