99 trail blaizer starting problem
Old Jan 18, 2009 | 08:37 PM
erichead's Avatar
Default 99 trail blaizer starting problem
Starts good cold...won't re-start after warm. Has good spark.
Tim
Old Jan 18, 2009 | 09:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check compression. make sure vent lines arent plugged or pinched.
Old Jan 18, 2009 | 11:07 PM
eggenz7's Avatar
you could also have a leak some where. everything is air tight when cold but after the cases start to warm up and expand it creates gaps. not a big problem if seals are still pliable but old seals will not handle this very well. after you get it running and warmed up try spraying carb cleaner around all gasket areas, intake boots and exhaust manifold if you notice an increase in RPM's then you have found an air leak
MikeyBoyesq
Nov 27, 2020 02:44 PM
buckshit
Sep 24, 2015 08:49 PM
garyt1975
Jun 5, 2015 08:53 AM
neilbedwell
May 31, 2015 11:11 AM
1000gade
May 27, 2015 12:37 PM
