Brute 750
Old Jan 22, 2009 | 12:18 AM
dune 400ex's Avatar
Default Brute 750
what you be a cheap way to make it go faster
Old Jan 22, 2009 | 11:53 AM
KneeBone650's Avatar
Default Brute 750
depends on how cheap you want to go. is it FI or carb.? do you have a price range in mind?
Old Jan 23, 2009 | 02:47 PM
dune 400ex's Avatar
Default Brute 750
about 500$
Old Jan 29, 2009 | 04:12 PM
Default Brute 750
well probably the best way to go is to get a K&N air filter and aftermarket exhaust. a power pack will take the delay out of the throttle... if the quad has a carburetor than i would look into getting a jet kit. Your local dealer should be able to hook you up with some stuff.. or go online to High Lifter and look at the stuff they got on there, they have decent prices there and a lot of good stuff... stay away from the belts tho, stock belts are better. A dynatek ignitor (CDI) will raise your rev limiter so you can get more speed.
Old Jan 29, 2009 | 06:33 PM
stillV1's Avatar
Default Brute 750
Clutch work will do wonders...just and aftermarket primary spring($25) wil do good. EPI or Dalton. Dalton has a clutch kit for less than $300 I believe and you can check HMF for the exhaust. Just my 2cents....Enjoy[img]i/expressions/beer.gif[/img]
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 10, 2015 06:45 AM
ylomnstr
Sep 4, 2015 05:02 PM
