Is my Hole normal?
Old Jan 23, 2009 | 11:52 AM
summerjack's Avatar
Default Is my Hole normal?
2006 sportsman 700 efi.
Changing the oil filter for the first time myself.
when putting the new oil filter on i noticed the hole with an abnormal shape.
is this normal for polaris?
http://s662.photobucket.com/al...view&current=hole.jpg
<br [/L]
thanks[IMG][/IMG]
Old Jan 23, 2009 | 12:04 PM
TLC's Avatar
TLC
Link brings you to Photobucket home page only.
Old Jan 23, 2009 | 12:27 PM
summerjack's Avatar
should work now. sorry
Old Jan 23, 2009 | 12:37 PM
TLC's Avatar
TLC
I don,t have a 700 but it sure looks like it belonges there.
Old Jan 23, 2009 | 12:43 PM
summerjack's Avatar
the shape is abnormal and the metal is thin. appears to be bad casting?
Old Jan 23, 2009 | 01:26 PM
Williebee's Avatar
Well summerjack if it weren't for the hole you would burn up the engine , this hole is the return route to circulate the filtered oil through the system.
Old Jan 23, 2009 | 01:28 PM
summerjack's Avatar
i realize it is a return but the odd shape and this metal was a concern.
any comments
Old Jan 23, 2009 | 01:48 PM
Williebee's Avatar
summerjack the main reason for the odd shape of the return port/hole is to make it big enough for a high flow rate , and also to keep from milling the port/hole to close to the center of the input port/hole where the oil filter screw's on ; it's faster and doesn't require milling more than one return port/hole in the engine casing !.....
Old Jan 23, 2009 | 01:59 PM
summerjack's Avatar
makes sense. thanks for your response!
Alex G.
Sep 11, 2017 11:38 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Sassinm1
Sep 30, 2015 04:23 AM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
