valve adjustment
Old Jan 27, 2009 | 09:59 PM
kaosbj's Avatar
Default valve adjustment
Hey i was wondering if the valve gap was different than stock if you have a hot cams stage 2. i know what the stock gaps are between the valves and rockers but i dont know if they are supposed to be different if i have the different cam. If anyone knows what the gaps are if they are different than stock i would greatly appreciate it
Old Jan 27, 2009 | 10:45 PM
TNHondaMan's Avatar
i dont think so man,because you didnt have to degree the cam, is it still the stock crank?
Old Jan 28, 2009 | 03:38 PM
kaosbj's Avatar
im not sure but i think so, if not it would be a hot rod crank but im pretty sure it is the stock crank
Old Jan 28, 2009 | 04:52 PM
JeffinTD's Avatar
I would think the maker of the cam could answer that?
Old Jan 30, 2009 | 09:12 AM
budedm's Avatar
It would be the same. No matter what the cam is, stock or other, you need the same clearance. I believe clearance is for valve stem growth and has nothing to do with cam or rocker arm growth.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
