Replacing 400 sportsman clutch springs
Old Jan 28, 2009 | 04:41 PM
jfg's Avatar
jfg
Default Replacing 400 sportsman clutch springs
Need some help! I am replacing the belt, drive clutch spring, ad driven clutch spring. Been surfing the net and trying to find a kit. Most replacement kits come with a new helix and new springs. The problem is mots only advertise for a 500 HO. Would it be OK to use this kit in a 400? It is used for trail riding and hunting. Should I just get the parts from the dealer? If the after market parts are close to the same price, then I'd much rather use them.
Old Jan 28, 2009 | 04:47 PM
ftwflh's Avatar
You have a 4stroke or 2stroke 400?
A 400 4stroke go with a Polaris white spring and the Aaen blue secondary spring and stock weights or if the lowend suffers go with 10MB weights
For the 2stroke go with Aaen green primary,Aaen blue secondary and S55 weights if not enough low end go with S58 weights
Old Jan 28, 2009 | 05:00 PM
jfg's Avatar
jfg
It is a 2002 Polaris Sportsman 4 stroke.
If I change out the helix, will it make that much of a improvement? Or will that be in the springs?
Old Jan 28, 2009 | 08:09 PM
ftwflh's Avatar
No need to change helix springs will do maybe weights too depending on how it feels with the springs and what you are taching
Land_shark1
Jul 10, 2015 12:53 AM
rotaxtwin
Jul 1, 2015 07:15 PM
VRRRRT
Jun 27, 2015 09:38 AM
Mphillips
Jun 26, 2015 03:52 PM
SaMs0nOLD
Feb 2, 2000 11:43 PM
