Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
z400
Old Jan 28, 2009 | 08:00 PM
teven's Avatar
Default z400
I have heard alot about removing the baffle can harm your engine. I have a k&n filter and have removed the baffle, and just checked the spark plug i put in 6 months ago and it looks almost new. Should i be worried?
Old Jan 29, 2009 | 03:13 PM
ss97's Avatar
Lets Ride!
Default z400
Well removing the baffle won't really give you any more power, it will just make it louder. And the K&N will allow more air, so technically you could be running slightly lean. But if you keep the air box lid on perhaps the K&N has not increased the air flow enough to make any real difference.
Old Jan 29, 2009 | 06:50 PM
teven's Avatar
Default z400
if your runing lean will the spark plug be black and sooty or white and burnt looking?
Old Jan 30, 2009 | 07:07 AM
ss97's Avatar
Lets Ride!
Default z400
If you are lean the plug will be white or yellow-ish........ and I've even seen them where they are cracked..........Since your plug still looks good as you say, I would think you are pretty safe.
Old Jan 30, 2009 | 03:17 PM
stillV1's Avatar
Default z400
Also...I would rather error to the rich side if my air /fuel mixture was a bit off...but as ss said if your plug looks as good as you say then I would think you are fine.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 1, 2009 | 09:35 PM
teven's Avatar
Default z400
if i was to take the airbox lid off what size jet do you think i should use?
Old Feb 16, 2009 | 10:27 AM
cataway's Avatar
Default z400
if you were to take off the lid and remove the muff.tip a 142.5 -145 MJ
by remove i mean using a hole saw and cutting the center out of the spark arrester that came with , or you could replace with an after market end cap .
just that much could bump your HP up to 3-4 HP ,change your air boot to a 400ex
boot and bump it up some more . after that HP starts to get expensive ,about
$100. per HP. cheep HP is the best HP.
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1ArmBandit
Sep 8, 2015 08:59 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
