Had my winch split in half...
Old Feb 2, 2009 | 09:57 PM
JCDEYO25's Avatar
Default Had my winch split in half...
Yup the 2 long bolts that connect the motor to the rest of the winch backed themselves out....It's a warn 2.5ci....I put some loctite on the threads when I put it back together....I never had it apart before, the end cap came off the motor and one of the 4 springs in there went flyin...Luckily i found it...kinda tricky getting it put back together but I look at it as a learning experience...just thought I'd let you guys know to keep an eye on those bolts...thanks for readin....
John
Old Feb 2, 2009 | 10:27 PM
firehog's Avatar
Thanks for the heads up. Just goes to show you that all winches can fail.
Does this mean we're going to get into another "winchoff"? I sure hope not! Getn tired of the winch debate......LMAO!
Old Feb 2, 2009 | 10:35 PM
JCDEYO25's Avatar
No that wasn't my intent......I've had great luck with it.....I just hope the loctite doesn't haunt me down the road if I ever need to get in there again.......I think I'll be alright...
John
Old Feb 3, 2009 | 12:58 AM
MrMarty51's Avatar
Red locktite needs some heat or real torque to get the bolts loose.
Blue thread locker is a bit more mild but will hold the bolts in in most cases.
Old Feb 3, 2009 | 07:08 AM
JCDEYO25's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: MrMarty51
Blue thread locker is a bit more mild but will hold the bolts in in most cases.</end quote></div>
Yup...I used blue.
John
Old Feb 3, 2009 | 07:16 AM
Ruggo's Avatar
Thanks for the heads up JD!
Old Feb 3, 2009 | 07:35 AM
teamplayer's Avatar
I had the same thing happen to mine about 6 months ago. I repaired the same way as you.
Old Feb 3, 2009 | 06:16 PM
Rickeyparker's Avatar
Im shocked My champion winch hasnt broken yet, But I havent used it yet either LOL
Old Feb 3, 2009 | 07:19 PM
RticKwad's Avatar
Runs Stealth!
Wow, good info. I have the same winch! I know when I installed it
both times (first time on my former SP450 and now have it on my SP800
after I traded up) those bolts that hold the winch to the polaris mount
are those hex 1/2 that just go thru the frame threads. I DIDN'T feel
secure about leaving it that way, so I added the nuts behind it, pain to
get behind it but nice and tight to keep the assembly from flying off.
Now the winch motor bolts to the mount plate? Geez, thanks for the info.
I will added this on my TO-DO, man will I ever get a free weekend? LOL
R'
Old Feb 3, 2009 | 07:32 PM
HIGHOCTANE's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: RticKwad
R'</end quote></div>
Not to get too far off topic but I know exactly what you are talking about R...those self tapping bolts that just screw into the holes in the frame..doesn't give me the warm and fuzzy either.
I was glad to see on the XP the winch mount bolts come in from the sides and there are "nut plates" in place to screw the bolts into...
The brush guard mounts are self tapping though..I added nuts to the backside of those just like you did to the winch.
Johnny Mac
Aug 15, 2019 03:13 PM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
1ArmBandit
Sep 8, 2015 08:59 PM
chewy78
Sep 8, 2015 10:37 AM
