98 Trailblazer clutch removal???
Old Feb 2, 2009 | 10:39 PM
quepasa69's Avatar
Default 98 Trailblazer clutch removal???
I am in the process of removing the gear box on my 98 polaris trailblazer. I almost have everything apart except the main clutch. I need it off to get the plastic shroud off to get to the bolts into the gear box. Am I needing to get a clutch removal tool or is there some other way to get it loose from the shaft? Also, how do the swing arm bolts for the rear end come out. I turned them but they keep turning, is there a nut on the other side somewhere? Any one done this before and have any pointers for a beginner? Thanks!!
Old Feb 3, 2009 | 06:02 AM
ftwflh's Avatar
You need a puller.Buy one and if you keep this machine it will be one of the most used tools you have.There are lots of jobs on these that are easy IF you remove the clutches.
Old Feb 3, 2009 | 07:11 AM
Kerbbirds's Avatar
Ditto on the puller and yes there are nuts on the backside of swingarm bolts.
ghost civic
Jan 15, 2020 07:43 AM
merryman
Jan 19, 2016 04:29 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
