kawasaki bayou 220 1994
Old Feb 5, 2009 | 08:04 PM
deets01's Avatar
Default kawasaki bayou 220 1994
[img]i/expressions/face-icon-small-confused.gif[/img] i have a 94 bayou 220 can anyone tell me if there is a fuse to the electrical system. the neutral light will not come on nor will the lights, have new battery,and relay the solsnoid is good, has power to the starter, it will not start with the starter button. Does anyone know the answer
Old May 30, 2018 | 09:20 PM
Jamiemcd03's Avatar
Default Relay
there is a fuse on the starting solenoid.
Old May 31, 2018 | 02:01 AM
Check that you have connected the new battery up the right way round, that fuse will blow if you get it wrong. It may also have blown the regulator.
Old Oct 11, 2021 | 08:42 PM
Clark_Elite's Avatar
hey guys I'm new to this for him so I don't know if I'm supposed to just ask my question on any comment or should I make my own question? I have a 1994 Kawasaki Bayou 220 and it runs great but when I give it Full Throttle it wants to bog down I pulled the fuel filter underneath be or I guess it's the fuel filter that comes off the gas tank where your shut off switch is but I couldn't find an actual fuel filter nowhere what else could be my problem? I put good gas in it and put a new spark plug in it everything else works perfectly it's just when I go to give it a lot of gas it's got a lot of hesitation like it's either not getting enough gas or something
Old Oct 12, 2021 | 03:04 AM
This is a different fault, so it would have been better in a new thread.
The only filter is the one on the fuel tap. Most likely cause of the bogging is a slightly blocked jet in the carb. Remove float bowl, remove jets and blow them and the holes they came from out with compressed air. Clean out float bowl, replace and see how it runs.
PaulG
Sep 30, 2005 12:12 AM
R254
Sep 11, 2005 10:08 PM
fappleman
Mar 20, 2001 11:47 PM
Fourtrax4life
Dec 30, 2000 12:31 PM
