Help installing brake seals
Old Feb 6, 2009 | 09:27 AM
mrk874's Avatar
Default Help installing brake seals
My front brake drum seals were non existant, so I got some new ones, planning on installing tonight.
It's pretty obvious where they go, but I'm wondering if I need to apply some grease or lube to them or the whole track where they sit before installing. I would expect I have to put something in there. Anyone know exactly what I should do, what kind of grease etc. I'm a novice working on brakes...
Also there's a partial notch cut out in one spot - where should this be positioned? Guessing at the bottom to allow for drainage?
Thanks for the help!
Old Feb 7, 2009 | 11:35 PM
DavidXP's Avatar
i always apply a little gasket lube to all my rubber seals so they don't dry out crack and what not
Old Feb 9, 2009 | 08:28 AM
mrk874's Avatar
Thanks. I ended up using some general grease to do the job Fri night. The brakes seem well sealed.
Now I can see that drum brakes are a pain to maintain. I've got everything together, drums and pads are dry but still little braking power. 25 year old adjusters are a bit hard to move.
Don - if you're reading this - we need to bust these open again someday and adjust them right! Thanks for the 1 1/8 socket loan too.
DeFox500
Aug 14, 2015 05:59 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Sandman2.0
Jul 21, 2015 09:03 AM
