belts,how long do they last on average
Old Feb 7, 2009 | 02:46 PM
povertyplainsman's Avatar
Default belts,how long do they last on average
I just put a belt on my 800 sportsman 2 mths ago (pure polaris),maybe put on 300 miles. I live in Northern Alberta,Canada and I have been riding allot of snow/ice. infact allot of spinning on the river we ride, more like 40 mile/hr drifting.Also some deep trails.
Could have blown because all the wheel spinning,but I just want to get some others opinions on how long they last and if this is the best belt to buy? Love to get some feed back from other riders,seems to be premature in my opinion.
Perhaps I need to do something else?
Thanks for reading and look forward to your response!
Old Feb 7, 2009 | 03:01 PM
WOLF1's Avatar
High range in deep snow is tough on the belt. Lots of fun...but tough!!
Old Feb 7, 2009 | 03:05 PM
DODGE57HEMI's Avatar
Mopar Man!
The belt will last a long time, if you ride like your owner manual tells you too meaning if your in a low torque, low speed situation to use low gear if you are cruising over 20MPH to use Hi gear! Basically use common sense at it should last a long time! I had my 04 600 with 3000 miles on when sold it and mine still looked like brand new!
Old Feb 7, 2009 | 07:39 PM
<div class="FTQUOTE"><begin quote>Originally posted by: DODGE57HEMI
The belt will last a long time if you ride like your owner manual tells you too meaning if your in a low torque, low speed situation to use low gear if you are crusing ove 20MPH to use Hi gear! Basicaly use common sense at it should last a long time! I had my 04 600 with 500 miles on when sold it and mine still looked like brand new!</end quote></div>
[img]i/expressions/beer.gif[/img] Good Answer,I repeat this same thing on a daily basis! Hard for it to soak into some peoples minds!
Old Feb 7, 2009 | 07:46 PM
ftwflh's Avatar
another thing that will blow a belt os the vents on the CVT stopping up with mud,snow,or the famous mouse nest
Old Feb 7, 2009 | 10:34 PM
jokout's Avatar
I have seen belts that have blown with relatively low mileage after repeatedly left in gear while idling for extended periods! One rider in our group had this bad habit till he went through two belts in less then 1000 miles...he was wearing spots into the belt where it would rub against the primary sheaves during idle, heat the belt and next thing you know he needed a tow! Finally learned his lesson and turns off his bike when he sites and gabs! We still take a lot of grief from the non Polaris riders in the group!
Old Feb 7, 2009 | 11:10 PM
Thanks for the replys from all of you,I don't have the idling in gear habit, but will take all sugestions into concideration.
I have installed another polaris belt, guess I will see what hapens.
Thanks again
Old Feb 8, 2009 | 01:26 AM
wvu304's Avatar
wat happens when u only have high? and no low gear
Old Feb 8, 2009 | 11:38 AM
H20's Avatar
H20
So no stories of belts lasting any longer than 500 miles, I have new bikes only 300 miles so far however I would assume you could get 2000 miles or more out of a belt. Am I wrong??
Old Feb 8, 2009 | 11:42 AM
Spdecat's Avatar
I have 3000 miles on my 2008 500HO belt .
