2003 ds650 sproket
Old Feb 8, 2009 | 05:19 PM
ZZTOP's Avatar
Default 2003 ds650 sproket
i have to change the chain and front and rear sproket on my ds and i not able to find the torque ( tork) on each sproket bolts anyone have a idea
tanks for your help
Old Feb 8, 2009 | 07:14 PM
brian 68's Avatar
my manual is for a 01, it list's 124 lbs ,
Old Feb 9, 2009 | 12:32 AM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
<div class="FTQUOTE"><begin quote>Originally posted by: brian 68
my manual is for a 01, it list's 124 lbs ,</end quote></div>
Foot or Inch??? Huge difference!
Old Feb 9, 2009 | 12:43 PM
Sport400inOH's Avatar
I would lean toward inch pounds - especially for the front sprocket. That sounds light, though. I would use 30 - 40 ft pounds if we can't find an accurate torque spec. Those front threads might not take 124 foot pounds - that is a pretty hefty load. The rear sprocket would most likely be around 30 foot pounds as well. Be sure to tighten in a criss-cross pattern on the rear.
Old Feb 10, 2009 | 07:52 AM
brian 68's Avatar
sorry i misread ,thought you were asking about the rear only . rear 124 lbf in
front 103 lbf ft , just to clarify the rear is in inches and the front is in ft . and yes it does seem like alot for the front , but look at the size of the nut,
Old Feb 10, 2009 | 08:25 AM
brian 68's Avatar
i saw manuals on e bay cheap. dont assume with the ds , i'v worked on bikes for years , and most of the torque spec's seem high, but most of the bolts are a size bigger than other bikes. so what has always worked befor might not be enough.
don't get me wrong . since you made me look it up i have to retorque mine. i will run a little less on the front , so i can chang it on the trail for drag racing. [ i hate to be beat] so far i havn't . i have the only bomb around, that get's ridden anyway so i got alot riding on it .
Old Feb 10, 2009 | 02:19 PM
TheStir's Avatar
Started riding ATVs in 1974!
I know the front is just over 100Ft Lbs like Brian said, I use 100 as its easy to set, but I'm going to look the rear up, 124 In Lbs (10 Ft Lbs) sounds kinda light.
These are correct per my manual, Torque Specs
Old Feb 10, 2009 | 09:44 PM
ZZTOP's Avatar
tanks all for your help
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
greg86hd
Sep 16, 2015 12:32 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
Hw00d
Sep 10, 2015 08:53 AM
chewy78
Sep 8, 2015 10:37 AM
