Accesory connection on Recon?
Old Feb 9, 2009 | 08:58 AM
pat6366's Avatar
Default Accesory connection on Recon?
Does the Recon have an accessory connection wire? I just installed a winch on my 2007 Recon and tapped into the red wire off the ignition, however, that wire is always hot and I'd rather have the winch not functional when the ignition is off. Thanks
Old Feb 9, 2009 | 01:57 PM
budedm's Avatar
Should be an easy fix to find a "hot only when running" wire. How about one of the wires that runs to the light switch?
Old Feb 10, 2009 | 09:00 PM
rolfe's Avatar
There is a switched black bullet connector and a green ground bullet connector taped inside the main wiring harness about 6 inches in front of the rectifier. The harness has a lump where they are.
Rolfe
95wolv
Sep 27, 2024 12:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
EIF
Apr 20, 2017 07:15 PM
Sw00p
Sep 24, 2015 02:50 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
