Can"t keep chain tight
Old Feb 9, 2009 | 01:19 PM
hypergt's Avatar
Default Can"t keep chain tight
I've got a 06 trail boss 330 and I can't get the chain to stay tight. I adjust it as said to by the manual loosen the two bolts on the rear end but punch throught the hole and roll the atv to tighten the chain then tighten the two bolts. I can go riding for a few hours put by the time I get back the chain is laying on the swingarm i'm talking sloopy loose. Cloud someone please give me some ideas on what to do to keep my chain tight.
Old Feb 9, 2009 | 04:39 PM
ftwflh's Avatar
Default Can
I would start by jacking up the rear of the quad and check the rear axle and swingarm bolts for play
Old Feb 9, 2009 | 04:47 PM
scootergptx's Avatar
Supersock
Hired Gun!
Are you loosening the brake caliper too?
Old Feb 9, 2009 | 06:09 PM
hypergt's Avatar
If your talking about the bracket that bolts to the side of the swingarm yes I loosen it when adjusting.
Old Feb 9, 2009 | 08:29 PM
<div class="FTQUOTE"><begin quote>Originally posted by: hypergt
I've got a 06 trail boss 330 and I can't get the chain to stay tight. I adjust it as said to by the manual loosen the two bolts on the rear end but punch throught the hole and roll the atv to tighten the chain then tighten the two bolts. I can go riding for a few hours put by the time I get back the chain is laying on the swingarm i'm talking sloopy loose. Cloud someone please give me some ideas on what to do to keep my chain tight.</end quote></div>
06 kinda early for chain to be worn out,but if chain has excessive side to side play on chain links(when chain is loose) then possible. Tighten chain to 3/8- 1/2" play in middle of chain between sprockets then TIGHTEN axle bolts to about 50 foot pounds! manual will give exact torque specs. When I adjust chain I just impact TIGHT! After adjustment jack up and turn wheel,if chain varies in tightness,tight,loose,then tight again,then chain worn.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
merryman
Sep 19, 2015 03:15 AM
