Warrior stuck in gear
Old Feb 9, 2009 | 01:52 PM
Gearhed's Avatar
Default Warrior stuck in gear
HI all Just joinrd up and have a question.
I have a Warrior that is stuck in gear. It lost the chain and it balled up around the sprocket on the motor and now it is stuck in gear. I got the chain off and it will start and run but the trans seem locked up any thoughts? I am going to start with the clutch.. I am looking for ideas. Thanks
Old Feb 9, 2009 | 11:45 PM
Dune Rat 2008's Avatar
your output shaft maybe bent which would lock up the tranny and if thats the case you will have to tear down the whole motor to replace the shaft it happened to me almost like that but mu sprocket came off and bent it
Old Jul 24, 2012 | 04:21 PM
warriorrider24's Avatar
my warrior is having similar problems i was going up a hill ***** out when i got to the top it sounded like it shifted up and then it locked up and died i could still start it fine and it ran great. it would go into the nuteral hole but still would die when i let out the clutch finaly after i got pissed and rapped it out and dumped the clutch it came loos worked fine but the day after it locked up again same fix but now it is making a grinding noise
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
heath legg
Jul 24, 2015 01:01 PM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
ghost civic
Jul 15, 2015 10:48 PM
