Sport Quads Discussions on sport quads.
Blaster Clutch Problems
Old Dec 14, 1999 | 11:11 PM
MrInSaNo's Avatar
Hey ... i was riding my blaster the other day when my clutch lever all the sudden got stiff to where i couldnt pull it in ... i pulled it a couple of times and then i finally was ably to pull it in .. i thought ok no big deal .. so then i started my quad back up again and tried to take off but when i let my clutch out nothing happened. i tried this in all 6 gears ..i looked at the left side of my quad where the clutch cable connects and when i pulled the clutch in the piece moved like it should.
My friend that raecs motocross bikes said it sounds like it might be my clutch basket. What might the problem be?
Old Aug 28, 2002 | 04:26 PM
theyamahakid's Avatar
could be the basket, or it might be a plate out of wack. the only way to find out is to tear it apart. sounds like something's bent or out of alingnment since it's not engaging. just drain the fluid, turn the bike up on its side and take the cover plate off. try tapp the plate with something to break loose the gasket. you might be able to save it that way. let me know what you find out-I'm kinda curious, never seen anything like that before.
skinnyr6
Aug 25, 2023 02:18 AM
Frisky2050
Apr 9, 2020 11:19 AM
honda71
Jul 12, 2015 05:56 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
